I have a 3310 Holley 780cfm carb that had an electric choke on it, but I would like to use a divorced choke. I have the bi-metalic coil assembly, and I just ordered the pull off on ebay. Where can I get the rest of the necessary parts to install this? Can someone please post detailed pics of the assembly so I can see what needs to be done?
Thanks in advance,
Rick
What parts are you looking for? If I recall, the choke assy pretty much fastens on side with 3 long screws, but links up to the rod and choke flap as well as shaft. Is that what you are missing? I have several assemblies that take a universal choke cable.
Rick;
You can't convert a 3310 to a divorced style choke, the main body is a completely different casting than an OE divorced choke style carb and lacks the required bosses and castings to install the choke components. A 3310 will only accept a manual, thermal, or electric choke.
Eric
