If you were closer, we could just reconfigure that hard line with a little tubing and the TIG welder….
or you make it fit, send it to me and I’ll make sure it doesn’t leak👍
I really appreciate the offer.If you were closer, we could just reconfigure that hard line with a little tubing and the TIG welder….
1" of tubing to go above or below times 200,000 units = $31.00 of cost reduction.I really appreciate the offer.
The thin wall tubing is 5/8" outside diameter and a magnet will stick to it. One of the end fittings looks like it was either soldered or brazed onto the tube. I heated it until it was a dull red color, and I still could not get the fitting to separate. After my futile attempt, I laughed at myself thinking GM used expensive silver solder to join the fitting to the tube.
Installing an aluminum -AN fitting on a steel tube might invite corrosion.
These are some of the reasons why I call it an interesting piece of junk. Why did GM route the tube between the block and motor mount? They could have run it above or below the motor mount.
The oil pan should arrive today. I have some ideas how to fix this PCV problem. I will post some photos if it works. So far, no JB weld or duct tape is in the plan.
Thanks again.
The ZL1 Camaro does not use plate style swap motor mounts.I really appreciate the offer.
Thanks again.
Yea, it was once a red scotchbrite wheel. It did not help much.That’s not a scotchbrite wheel is it?
you will blast and clean and put that pan in the dishwasher ( when your spouse isn’t home) right?
I’m over the top against that stuff around an open engine….
I removed the water pump and the stock catch can. I shook the catch can and it does not rattle. It is baffled. I can see a metal plate if I look down the large top hole.I am not sure that the catch can is a simple can. Somewhere in the system are check/PCV valve(s). I recommend the Holley part, this is no place for experimentation imho. Bad things can happen in supercharged engines if they are not properly vented.
I was able to use the stock LT truck pan but it was a truck build with a lot of ground clearance.
Don
If you can't go near the dishwasher, I would say you are making very good progress.The closeup photos of the TSP oil pan shows the worst areas. The machine surfaces are not mirror smooth. But do they really need to be? Both had casting slag inside the pan.
It is just an oil pan. As long as it does not leak, that is really all that matters.
I took the pan outside and cleaned it with my power washer. I blew out the excess water. I sprayed it down with brake cleaner. It has been sitting upside down on my bench for a few days.
I was told by my better half that I broke the dishwasher's pullout trays wheels by kicking the lid closed with my foot. I bought her new wheels to make up. Then the pump broke. It was said the pump broke because I put dirty dishes in the dishwasher. Apparently, you are only supposed to put clean dishes in a dishwasher. I replaced the pump. Now she will not let me near the dishwasher. I am good at tearing up things. Sometimes I can repair them.
Now you just need break the clothes washer, vacuum, and the trash can and you a good to go!I was told by my better half that I broke the dishwasher's pullout trays wheels by kicking the lid closed with my foot. I bought her new wheels to make up. Then the pump broke. It was said the pump broke because I put dirty dishes in the dishwasher. Apparently, you are only supposed to put clean dishes in a dishwasher. I replaced the pump. Now she will not let me near the dishwasher. I am good at tearing up things. Sometimes I can repair them.
The purpose of the check valve is to allow the catch can to drain when the car is not running. Engine vacuum will keep the valve closed when the car is running. At least this is my understanding.I removed the water pump and the stock catch can. I shook the catch can and it does not rattle. It is baffled. I can see a metal plate if I look down the large top hole.
It has a lot of bends in the plastic on the front side. This would be hard to recreate at home.
The bottom part has the special fitting for the hose that goes to the oil pan. It is mounted at an angle.
The engine was shipped full of oil. I glad I did not spin it upside down on the engine stand.
Here is a closeup of the check valve that is screwed into the oil pan. It is normally open. The ball would have to travel up to close the orifice.
I think there is another check valve where the hose connects to the intake manifold. More of a conventional PCV valve.
Later LS engines used small diameter orifice tubes in the valve covers instead of PCV valves afaik. Crankcase ventilation and resulting oil consumption was a bit of a cluster on early LS engines.
Don
