I have a holly street avenger 670 on a 327 (68 camaro). it continues to run rich. I do not know much about cars in general. I have reset the idle screws, did nothing. What else can I do to control the smell of straight gas and exhaust smell in my car? I have headers with a mix of piping of various sizes heading back to the two mufflers.
Thanks.
I have the same carb on my 350. When I put headers and new exhaust it stumbled when hitting the peddle and sometimes would die. I bought a vacuum gauge kit off of ebay and followed instructions found on the manual here > http://www.holley.com/data/Products/Technical/199R10219-3rev4.pdf
After I adjusted the idle mixture screws with the gauge it now runs very well.
Thanks.
I assume your 670 Holley is a vacuum secondary carburetor?
Does it have four corner idle or just two (how many mixture screws does it have)?
If the car won't stall when you turn in the mixture screws then the power valves are shot and need to be replaced. You need to connect a vacuum gauge to the full manifold connection on the carb and take a reading and take 1/2 of that reading and that's the power valve size you need in the front and rear. Once that's fixed you need to get the car to operating temp and adjust the idle mixture screws.
Turn in until the rpm drops or your vacuum reading drops then turn out 1/4 turn. That's be the leanest idle.
Then go for a drive on the highway for about 30 min and take a spark plug reading. You may need to re-jet the front jets to a lower number if it's running rich.
check the level of the floats
I have a holly street avenger 670 on a 327 (68 camaro). It continues to run rich. I do not know much about cars in general. What else can I do to control the smell of straight gas and exhaust smell in my car?
How does she run? You say "you don't know much about cars" but exhaust from carburetor cars will put out fumes that smell VERY different from your newer Ford or Chevy or whatever.
If you're smelling raw fuel, you have a leak somewhere. Start looking for wetness at the fuel tank then follow the fuel line to the pump then carb, then check the carb itself for leakage.
Banned
Not enough intial timing, too much thinking an out of the box carb can be bolted on and off you go. Read Timing 101 sticky on this site and the instructions that came with your Holley carb on how to dial it in. These cars of ours our not turn the key and forget it.
