1 - 14 of 14 Posts
Anyone use the supplied exhaust manifold gasket that comes with a new set of Hooker headers?? Looks kinda cheap. I was wondering if I should just buy a new set of Felpro's?? Thanks.
Always had good results with Mr. Gasket Ultra's.
Might take a file and smooth the head side to lay flat against the head to seal better.
Thanks.
try Remflex gaskets...a little expensive, but they are easily the best out there...
I'm with Everett's recommendation. I like the Mr. Gasket Ultra-seals. They are usually in stock at Kragen's/O'Rielly. :thumbsup:
Discussion Starter #8
Thanks everyone for the replies. Should I just trash the Hooker supplied gaskets then ??
Where can you buy these header gaskets. I am having the WORST time with the drivers side (of course) on a 69 BB with PS. I sent the header to a machine shop to have the flanges welded and remachined where Hooker ground them off uneven. I even tried 2 gaskets and still have a small leak. Thanks
bought mine online, also earls makes a pressure master seal that uses a soft replaceable seal in an aluminum flange, had good luck with those as well. something i saw the other day, is new and i have no experience with, dei makes a paste for turbo flanges that they say will seal a .050 gap after curing under boost pressure. curious if it would work okay for header seal.
Actually before you trash anything - I only use the Hooker gaskets and never had a problem. Overlay your Hooker gaskets on the header flange - it should a perfect fit.
Discussion Starter #13
Thanks Tom, I will try it.
I htink the only place that you can buy them is direct, via their website...
http://catalog.remflex.com/
Solved all of my leaking problems...
1 - 14 of 14 Posts
