OK, here's another one and might be why some of my other things aren't working correctly. The new kit mentions nothing of wiring up the horn relay...just shows the green wire for the horn...that's it. So I do not have the relay installed. Need to know what/how to wire it up? I saw on the Where Is It pic that it's got various connections into it but I don't understand why AAW wouldn't include all of these connections if this relay is needed.
Anyway, let me know #1 if it has to be there and #2 if it is needed what the heck do I wire to it besides the horn, 12v and ground.
Thanks again.
The "where it is pic" has no relevance for you, because you are installing the Classic Update, correct?
The horn relay function is performed by the horn relay provided in the Update kit; the buss bar function (all the other connections shown in the "where it is pic" and in factory wiring diagrams) is not used by the Update kit. Power distribution in the Update kit is different and arguably (I'm sure some GM engineeer somewhere would argue theirs was better) more efficient and straightforward.
The hardest part of the Update kit is having to cast aside your OE diagrams and OE harnesses and trust and follow the directions. I got hung up too, and because I am a knothead engineer, spent over an hour on the phone with Donny Bock at AAW while he explained all the circuits and how they had been improved from factory routing. I have all my notes, but can't get to them because I am temporarily wheelchair bound.
So, again to answer what I think is your question, you do not need the OE horn relay that mounts on the driver side radiator support with an AAW Classic Update kit. The kit supplies a small, modern relay for the horn circuit, and you'll end up mounting it somewhere inside the car near the instrument panel. Any other wires on the OE hron relay buss (like the alternator lead, power window/accessory feed, etc) will come from other parts of the Classic Update kit.
Trust the instructions, and when in doubt ask here or talk to Donny Bock at AAW (call and ask for him, and tell him you got his name here). He's forgotten more than I will ever know :).
Thanks alot....Didn't think it was needed any longer but appreciate the confirmation.
