I'm transplanting an LS1 into my 1969 and I need a wire that is +12v in both run and start position. Can I simply wire both the purple wire and resistance wire together to get this "hot in run and start" wire?
I was going to suggest this idea, or a time delay to OFF relay supplied by ignition voltage.You could also connect your IGN wire to a relay and install a capacitor accross it - say 10uF. That should keep the relay engaged for a 1/2 second or so to hold it through the drop out.
