1 - 17 of 17 Posts
Ok, got the steering column and power steering box out of the car right now and thought I'd try to fix the leaks. While taking it out, I thought about whether or not I should replace the rag joint? It appears to be in pretty good shape, but is original, so how do I tell if I need a new one? If I do replace it, how do I get it off, looks like it is permanently attached?! Or does it come with a new collar?
Thanks,
Bill C.
Bill C.
Colorado Springs, CO
68 Camaro... someday!
71 Chevelle SS
70 Nova
You can buy the coupler assembly from the chevy dealer or from camaro restoration sources. It cost around 70.00 for GM coupler. I think they make a reproduction, but from what I have read they are not recommened for safety reasons. I would say go ahead and repalce it now while you have everything tore down. If it is original, it has alot of wear. Better safe than sorry!
I agree with yogi. Replace it. I bought one for the wife's 69 when I restored it. GM does want an arm and a leg for it but safety is never too expensive. Good luck with the car. Jim
69 SS, 350, 4 Speed
75 400, 4 Speed
93 Z28, 6 Speed
The only ones I have heard about being a safety issue are the type that come in a rebuild kit, you have to put them together.
Thanks for the responses guys, and thanks for the link Mark, That's what I what! I'll check with GM on Monday, but if they want $70 for new, I'll stick with D&R or Classic for the $30 one. All I can find in the parts houses are the rag part and you have to re-use the coupler. Don't like that idea...
Bill C.
Banned
The D&R part is only half of the joint if you have a tilt steering column car. The other half bolts onto the bottom of the column's shaft itself. pdq67
Discussion Starter #9
pdq67,
I can't afford to drive a luxury car that has things like tilt steering!
That picture is just like what I took off, no other pieces required... Now if I can just get that stupid ignition switch out!
Thanks again,
Bill C.
Discussion Starter #11
Ok, I gave up on the ignition switch, so I'll just have a key made for it!
pdq67,
Actually, if I want to feel special, I take the Chevelle out for a spin as someone swapped in a later model column that does have tilt capabilities. Then I also get to feel the big block and take out my frustrations on the tires!
Still don't have any AC tho!
Bill C.
I rec'd my ragjoint from D&R a few day's ago. Seems to be of decent quality (alot better than what I took off!). The only thing I suggest is I will probably replace the two bolts that bolt to the column with grade 8's and nyloc's just for safety and maybe the pinch nut with a grade 8 too. I doubt they would even want to sell them if they weren't safe.
MStarmer
1968 Camaro 350/TH350
http://photos.yahoo.com/mstarmer1
Discussion Starter #13
Good idea MStarmer, I'll get some new nuts when the rag joint comes in today or tomorrow hopefully.
Bill C.
Discussion Starter #14
Got the new joint today, looks like a real nice piece except... for the bolts! Not sure what they were thinking, but with the nuts on the bolts that came with it, there is less than 1/8" of the bolt sticking out the nut. To me, this would definitely not leave enough bolt once you get the column flange in there also. Definitely going to replace the bolts, but otherwise, I recommend this piece.
Bill C.
Ordered my part today from D&R today. When replacing this part, do the steering column and the steering box have to go back togther exactly the same way? In other words, if I moved the steering wheel in the car while disconnected to the box will things still work correctly. Thanks
Steve
Discussion Starter #16
You may not have realized it, but everything below the steering wheel is keyed to go one way only. The steering coupler (rag joint) actually has one bigger and one smaller nut/bolt combo so it goes onto the steering column a certain way. Then the steering box had a small flat spot on one side that will line up to a small flat spot inside the coupling end that goes onto it. Then you just put the steering wheel back on! and hope it lines up right... mine never does!
Good luck,
Bill C.
BC,
Are you saying the part that does not line up is the direction of the steering wheel? Not sure I get it.
Thanks again
1 - 17 of 17 Posts
