I have a TH350 that came in my 69 Vert. The previous owner bought it from Jegs, it's probably got less than 2000 miles on it since it was bought.
I fixed the first 2 issues present when I bought the car pretty easily, the pan gasket leaked (overtightened bolts and a cork gasket) and the rooster comb was loose on the shift shaft. Since then it has functioned perfectly.
The trans has always leaked out of the output seal. I replaced the seal and the slip yoke (with a used but unscored yoke) first, then replaced the seal again when I installed a Denny's driveshaft (with a brand new slip yoke) fabricated to work with the QP 9" rear I installed last year. It still leaks quite a bit of ATF past the slip yoke when sitting. It've very annoying.
The engine is being replaced with an LS1 in a few months so I'm gonna pull the trans at the same time. It would be great to resolve the leaky tailshaft once and for all.
Any suggestions?
Joe
Any suggestions?
Joe
