How do you install the cocktail shakers in the front of a 68 RS? Where do they bolt up and which way do you approach putting them in? Are they in front of or behind the radiator support? I think I've read every thread there is on them but installing them has not been covered.
Thanks all
I think that I installed them from the rear. I had the headlight buckets out as well. There is 2 bolts on the radiator support and 1 on the fender. They mount pretty much even with the radiator support. It has been awhile so I could be wrong on the number of bolts on the fender and radiator support however. they are easy to install if your body panels are in alignment.
-Randy
Cars:
<A HREF="http://www.camaroclubkc.com/rs1968ss.htm" TARGET=_blank>68 RS/SS BB ragtop
</A>RWHP: 329.4 RWTQ: 398.9
63 Nova II ragtop
Club:
Camaro Club of Kansas City
They go either end of the rad' support & the mountings are plaiced on the front of the support with a bolt at the top & bottom from the rear, also there is a mounting that is fixed by a bolt to the flat part of the inner fender just next to/& to the rear of the rad' support.. The filler plug on shaker points upwards. I hope this helps.
T.P.donaghy.
http:community.webshots.com/user/tpd67
