1 - 20 of 30 Posts
Well guys, I finally ordered 17's!!
I really hope they'll look great. I've always had 14's and 15's on my camaro. I'll try and take some pics and post them after they're on. I was trying to find out how much difference in sidewall height there would be between the following:
275/40/R17 and 255/50/R17
also 245/40/R17 and 225/50/R17
The tire guy suggested running the 50 series with the width I mentioned above so they wouldn't look too thin of sidewall, and probably to allow a tiny bit of pothole insurance lol. So I was just trying to find out how much actual difference in sidewall i'm lookin at. Thanks
Very close to the same diameter, but the 255/50 will be an inch narrower than the 275/40.
Again, same diameter between the two, but the 225/50 will be a half inch narrower.
IMO, run the 275/40 and the 245/40. It's a tried and true combination. Looks and works great.
What size rims would I need for that combo? 17x8 and 17x9.5? I actually have a pair of nittos layin around that are 245/40/17 so those would work in front, and I'd just need the rear tires
Well Scott, I think the rim/tire place is gonna order up the combo you mentioned. And also have the other one they already ordered on hand in case there are problems with it fitting. I think it'd be nicer to have the combo you mentioned, I just hope there isn't any rubbing because I don't really want to modify any of the fenders.I'm hoping the wheels/tires will be on my ride by this weekend. I've been rolling around "GHETTO STYLE" ;) lol. I have black steel wheels in front, and some older style centerlines on the back.
I understand that 275/40/17 and 245/40/17 is the combo to run.I need to verify 1 thing though, and I haven't heard this yet. WILL THESE RIMS/TIRES TUCK INSIDE THE FENDERS??? If they won't then I for sure don't want to run them. I like a low stance with part of the tire tucked up in the fenderwells. So if anyone can tell me this please let me know.
Discussion Starter #9
Thanks Scott, your camaro is beyond sweet! I have a set of nitto's already at my house, I was wonderin if these would work in the front. They probably are really close to the size you suggested. They are 245/45/17 . I have to replace my cooling system too, so if these will work it'd be helpful. Then I'd only have to order the rear tires. Thanks.
Discussion Starter #12
Thanks for checking that Scott. Jigga, for the 17x9.5" rears they will have 5.5" back spacing
17x8" fronts will have 4.75" backspacing.
I had told the guy this is what I wanted and he was like NO, that won't fit, but I was pretty sure it would after doin research on here, so hopefully he won't get all bent out of shape when I tell him I want to run what I originally wanted not what he ordered, but we'll see.
Banned
FWIW??
The section width x the sidewall percent x 2 + the rim diameter = the tire diameter!! (All in inches!!)...
Hope this is of use to help figure what looks good in a wheel well opening..
pdq67
Discussion Starter #15
i'm hoping by saturday they'll be in so I can get em mounted and drive home. If they are, i'll borrow a digital and take some pics and try to get them to whoever wants to see them. That way jigga you can check out how they fit/look. Hopefully everything will go smooth , hehe. I'll keep everyone posted. Thanks for the info Pdq67.
Luke
Discussion Starter #16
Does the fact that my car has drum brakes all the way around have any affect on running the setup? It has the stock 10 bolt. Not sure , but thought i'd double check. I think the tire guy is gonna try and tell me that this isn't gonna work/fit. I don't feel like I should be responsible for the restocking fee of what he ordered instead due to the fact I told him what I orginally wanted, and he said it wouldn't fit, but never looked into it.
Luke, when I first got my 17's, I had drums in the rear, and it worked fine. Later, I switched to Baer brakes all the way around, and I still had no problems.
As for the drums up front, I'm not sure how much that effects track width, perhaps someone will chime in that's worked with that.
There are many sites out there you can find by doing a Google search that will help you determine the difference in two tire sizes. A site I particularly like is listed below. It will help you determine overall diameter, width, sidewall height, as well as the difference in circumference and percentage change in speedo readings. I apologize I am new to Camaros so I don't what will/won't fit but it worked quite well in figuring out what sizes I could fit under my early Nova. Hope this helps - Brian
http://www.csgnetwork.com/tireinfo4calc.html
Banned
Disc's are about .30" thicker then drum's at the stud mount so your wheel width will widen by about .6" front and rear if you go a four wheel drum to disc conversion using drum hubs.
If you use either two-piece hubs or machined down cast '69 type rotor/hubs less the rotors, the front will widen about .6" + 1.1" to 1.2" or so for a total of about 1.75" increase!
This is b/c the rim mount surface, (or what is called the "Joe" dimension b/c Joe named it first over on the Team Chevelle site), is about .6" closer to the small end of the hub vs the drum hubs "Joe"!!
I bring this up b/c I have two-piece hubs on my car now along with 13" rotors and custom caliper brackets to mount the big single piston calipers. (My front calipers are Van type that are 1/4" wider at the pad throat vs stock, '69 Camaro ones)...
Do a search for my "pdqCBB" four wheel disc conversion if you want to. I figure it is the cheapest one going for big brakes!! And my rear rotors are 11.75" ones...
pdq67
1 - 20 of 30 Posts
