Taking a break to post this so I hope when I am done with the install after lunch I can get the answer. I am putting a new brake system on my 67 today.
I am installing new brakes on all 4 with new wheel cylinders, new master cylinder and new lines so a whole new system. This is all drum with manual brakes.
Rear brakes are done, I am going back out to install new lines, then to front and then the master cylinder.
I know I need to bench bleed the master, but the lines are all empty as the new wheel cylinders. What is the way to do this to get fluid and air out of system bleeding the wheel cyl's. Do i do the rears first?
Thanks,
Joel
Joel, Are you bleeding the brakes yourself with no assistance? If so, and you have no brake bleeder system, I suggest purchasing SPEED BLEEDER (one person brake bleeders with built -in check valve) Part # DORMAN 12704. NAPA, Autozone, Kragens, etc has them usually. Two self bleeder screws come per package. So you will need two packages. Follow the simple directions and leave them in. Also, start with the furthest wheel from the master cyl first...rear passenger. Worked for me. Make sure you slowly pump the pedal. I pushed a clear hose onto the bleeder screw and stuck the other end in a bottle to catch the expelled brake fluid. Plus you can see when the air is released by a steady flow of brake fluid. No need to close screw between pumps- check ball will not allow air in. $10 per package. Took me 4-5 slow pumps of the pedal per slave cylinder. Do not let the master cyl reservoir fluid level get too low or you will suck air and have to bench bleed the master cyl again. I will never use my pressure bleeder again.
I wish I had known about those bleeders, I would have tried them on mine instead of buying a power bleeder. I used a power bleeder and it worked very well with some modifications to the clamping part so it didn't leak. Put 1 quart through the system to flush it and quickly had a very solid pedal. It was from Motive Products, got it from Summit for about $50 I believe. If you get one of these make sure you pump up the system with air first to make sure there aren't any alr leaks where it sits on top of the master cylinder, once you have a good seal add brake fluid and it works great!
I purchased the same one years ago. It wouldn't seal up my '68 Mstg Fstbk or my 66 Chevelle SS. The "J" hooks, cheapo chains and the composite lid suck! Been sold on SPEED BLEEDERS ever since. Fast and easy and in place for future use. :hurray:
