Center it before install
Pitman arm should be facing directly to the rear.
If it's anything like it was on my 68, you just don't worry about it.
Pitman arm had a "fat Spline" only went on one way.
Ragjoint to steering box had a "Fat spline" only went on one way.
Column to ragjoint can go on right or upside down. Look at the end of the column in the car, there is a fine line scribed from the center out, make it point up when the pitman arm points straight rear.
