I recently damaged my transmission and decided I would try to fix it myself. I've never gotten any deeper into a trans than pulling the side cover off so I knew there would be a learning curve. I found very little help on the disassembly process on the internet and have one printed document but I think a picture is worth a thousand words so I'm posting this so others can work with my photos and be able to disassemble to the point where you can change bearings, sychros and inspect most of the guts. The only special tool you need is a set of snap ring pliers.
Notice I am not calling this thread "how to rebuild a Saginaw" because I claim no expertise at that. Hopefully those who are experts might want to contribute their tips later in the thread.
So here we go...
Get the trans out of the car. Balance it on a 5 gallon bucket and remove the lower tailhousing bolt and the fluid will drain into the bucket.
With the sidecover off you may be able to see what is ailing your trans. There is a magnet affixed to the bottom of the case. Look for broken gear teeth, and metal parts stuck to the magnet. I found a broken tooth in mine.
While the trans is draining, you can remove the 4 bolts holding the bearing retainer in place and remove the bearing retainer. Try to save the gasket.
Now, while it may look like things are going to come out the front of the trans, they are not! Only the bearing comes out the front....
Using your snap ring pliers, remove the snap ring in front of the bearing off the shaft.
Grab the shaft by the splines and yank it toward you. It will move about 1/4".
Next use a screwdriver to coax the bearing out of its seat in the case. The bearing will slide past the splines and off the shaft .
So here we go...
