1 - 11 of 11 Posts
I'm trying to loosen a frozen nut on the flared end of a PS hose. I have the unit off the car and the tube held in a vise but when I try to twist it it wants to twist the tube. I've soked it good in rust breaker for days but it won't give. Can I use a propane torch? I've never done that. Is PS fluid flammable?
Heat the tube up until it is too hot to touch and then melt a piece of wax into the threads and the tube (behind the nut).
Works for me!
TONY
67 CAMARO R/S CLONE, 355/turbo 350, 200hp NOS,12 bolt,etc...
Ussually I just wait long enough for it to bee cool enough to touch (not cold). I did this on some trans cooler lines and I just wiggled the wrench back and forth and then turned.
TONY
Hate to say it but maybe you ought to just pinch the line and cut it. Then you can get a 6 point socket on it and it will come off easier. If it already has twisted a little the tubing is already distorted and may leak when you put it back together anyway.
Don't do the torch man!
Good luck - those can be knuckle busters.
have you tried throwing stuff and shouting every "forbidden" word you can think of as loud as you can, a few times over? usually, right after you do this and somehow hurt yourself, it will come right out.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
[This message has been edited by novaderrik (edited 03-09-2002).]
<BLOCKQUOTE>quote:</font><HR>Originally posted by novaderrik:
<HR></BLOCKQUOTE>
Yeah, but you'll throw and break something much more expensive during the tirade . . . at least that's what happens to me.
LOL
Discussion Starter · #11 ·
FREE at last, FREE at last, Praise God almighty I'm FREE at last.
I tried it all. I stuck the end in a can of water I had boiled on the stove. No luck. I brought the unit into the house and held it in a pan of water and boiled it for 5 minutes. No luck. So I put the torch to the fitting and kept wiggling it until it start to move a little then I sweated candle wax just like you would sweat copper pipe and eventually it freed up completely.
It doesn't seem to have hurt the pressed on fittings. I guess I'll find out when I put it back on.
Thanks everyone.
1 - 11 of 11 Posts
