Can anyone tell me how to remove the rear hard brake line from a 1968 Camaro with automatic transmission. I have the entire line unbolted from the frame and proportioning valve. I am installing a CPP front drum to power disc conversion kit and I need to fix the line as I put a kink in the rear line when bending it towards the proportioning valve. I was going to remove the line; splice a piece into it and re-install it. It looks like it is impossible to remove the line even though 80% of it is free from the rear on up to the bend in the frame where it goes up past the steering box and up to the master cylinder. Should I just cut the line near the frame rail and install a new piece that way?
Any help is appreciated from those who have faced similar issues.
Thanks,
Alan
Thanks,
Alan
