Pull the Connections on the 70 motor and plug them into the 80 motor. Ground the body of the Wiper Unit. Your 70 motor may not be burnt. 9 times out of 10 the Lower Bearing is seized. You can dissemble the unit but do not suggest you try to take out the Stator and windings - just lift the stator shaft, clean bushing contacts, blow out case and spray the bottom bearing area with Rust Check and oil with something like 3in1 or bearing oil.
Banned
Discussion Starter · #3 ·
that's the problem i don't have any connections. they were all cut ,it was an ex race car.
