Can anyone tell me how to troubleshoot a non working brake light issue? I know that the E brake and the master cylinder will turn it on but I have nothing at the Ebrake pedal and the rear MC went dry and no light ever came on for that. I did swap the bulb with one I knew that worked and still nothing.
There should be a tan wire on the brake block under the master cyl, unplug and ground this wire to test the light circuit. The key must be on of course. The emergency brake switch is the same color wire, ground it at the E brake to test that.
David
The e brake switch is very rusty and I could not pull the wire out of the rear but will try again.I'm also missing the paddle for the e brake switch.
I know where the tan wire is to the MC, when I ground it the bulb should light correct?
With both switches open (wire disconnected or park brake switch taped open since the paddle is gone), you should be able to measure battery voltage at the end of the tan wire to ground if the bulb is good, no broken filament or broken socket ear.
As David suggests, touch the wire to ground and light should light with the ign key on IGN.
With the cars ignition switch in the on position I pushed open the parking brake switch and had a reading of 10.5 volts. Then I pulled the bulb the right side prong had 10.5 and the left side prong had about .50 or something like that. I could not get the hood open because the car cover is stuck/frozen to the hood. I will find out what the reading is at the M/C soon. Do these readings sound good? I still cant get the tan wire out of the park brake switch.
If you have battery voltage at the tan wire at the p/brake switch with the switch pushed open, this is good.
With the switch closed, the light should light if the switch is making a good ground connection.
If you have 0.5 volts at the socket key, then the p/brake switch being closed is not making a good contact with ground - high resistance.
Steve,
I'm going to move this thread to the Electrical section, it's more appropriate there and you may get more help.
10.5 volts is a BADLY DISCHARGED battery, or resistance in the system. Check at your battery and see what voltage is there, or check the cigarette lighter voltage if you can't open the hood right now.
David
STATE OF CHARGE ----VOLTS engine off.
100%---------12.66
75%----------12.45
50%----------12.24
25%----------12.06
0%-----------11.89
Steve, as a generic test procedure, you need an ohm meter and the Camaro wiring diagram. you need to test each leg of a circuit against ground to see if you are getting the 12 volts. If you do not get 12 volts, you need to backtrack the circuit until you do and follow it to find the break. A LOT of common problems on Camaros are caused by poor grounds, so you check that first. On old cars its rust, on newly restored cars its paint layers. have fun!
You should not have to remove the e-brake switch to test, just poke the ohm meter leads on the switch.
Steve, those are the ground feeders (bat to engine, engine to body, body to subframe), Generally each wiring harness has a ground wire, some like the main dash harness have a couple. So in addition to making sure you body is grounded to bat, you need to make sure harness has a good ground to body.
Related Threads
Team Camaro Tech
2.4M posts
83K members
Since 1998
