I have a 67 Camaro RS how wide of a rim can I put on the front and back of my car? I want to go with some Davinci Rims :beers:possibly a 22 on rear and a 20 on the front. Wills this work or what is the max size rim I can get without doing mod on my car:noway:?
275s / 285s out back and 245s / 255s up front. The 285s Ace is running are being pulled in a bit making the 285 section width a little less then if it were on 10" rim. If your running 22s, your not going to have that option as you will have a VERY low profile on the tire, and will need to have the tire size and rim size nailed because you won't have the ability to pull those sidewalls i like you could with a shorter rim.
