I built a 351 windsor (yes a Ford!) for my next door neighbor and during cam break-in, I lost 2 lobes on the cam. I built this engine like I have been doing for 25 years and have never had this problem. I done a lot of reading and talked with some engine builders since then and I am amazed at the huge increase in hydraulic cam lobe failures in the last couple of years. It seems as though the oil companies are not putting zinc and other anti-wear additives in the oils like they use to. Comp Cams says that is why their cams are failing. Have any of you guys had this problem? Is Lunati and Crane experiancing the same failures? Not everyone can afford the triple cost of putting roller cams in their engines. I wonder if putting a bottle of GM E.O.S. in every time you change oil would help. Any opinions would be greatly appreciated.
