...to have a few things done. When I got it back and back home I noticed the "cloth -looking" ground that goes from the fire wall, (near the trans dip stick) to the block was not attached. Where should this ground be attached at the engine? And, could this be the reason my radio is not sounding right?
To the Valve cover bolt. Give it a try and see if it fixes the static. Do you have the "Noise suppression condenser"? It should be attached to the voltage regulator.
what shop was it so I know not to go there.
