21 - 40 of 93 Posts
Discussion Starter · #21 ·
While valve train is suspect......given this is a 4 speed car and "burnout" and 6300 RPM....you may have broken a spring on your clutch disc
I so hope it's a trans thing, then I would just do a TKX swap
Well you have homework to do. If you just busted a disc spring that is not a major fix other than minimally a disc swap but yeah that involves dropping the trans to see
Valve train is suspect given your note on the high RPM and "valve float" statement also.
those $5 stethoscopes from places like Harbor Freight are handy to probe for noise sources....
Have you pulled the valve covers yet? May be as simple as a busted valve spring
I've done that a couple times and hit mine at 6700 o_O
I use the 6500 RPM chip on my MSD 6AL, I also have a 3500 RPM "wife chip" (just in case)
1968 Camaro 1975 camaro
My wife can't drive a stick(I've tried teaching her but she is scared due to it wanting to burn rubber when she tries to take off)
I will put one a wife chip in the 68 though 😁
Discussion Starter · #27 ·
Ya think this might cause some vibration??
Fired the car up, engine sounds good and normal then I saw the fan pully wobbling so shut it down. Didn't know if maybe the pulley had cracked or what and didn't want it to come apart. Took the fan and clutch off and then the pully, The damn hub spun on the water pump shaft.. wtf???
well I have to say it...."chrome won't get you home" :cool:
At least it will be WAY easier to fix than valve spring or clutch
FWIW my buddy in his SC LT1 doing donuts threw his belt and same thing happened
The tensioner was stupid tight...is yours?
Discussion Starter · #29 ·
It's a spring loaded tensioner that came with the Concept One kit.
Discussion Starter · #30 ·
Anyone know of an application for a reverse rotation short BBC water pump where I could get one from a local parts house?
I'm glad that pulley didn't leave you .......when the summer comes along.🎼 🎧 🎧 :cool:
Reactions: Just 1 More
So you’re water pump wasn’t turning when you drove home after the incident and your temps did not skyrocket?
My 1st call would be to Concept One. Should be warranty.
Discussion Starter · #33 ·
Yes, water pump was turning, just wobbling. It's over 12 months old so I know they'll fight me on that But Yes, I agree, should be warranty
Led Zeppelin....
My reverse rotation pump came from CVF Racing, so I don't think it would be available at AP store. Couldn't you just go and tell them the year of your engine, then say pick "Camaro" then they should be able to pull up a water pump with a serp belt so it would be reverse rotation, right?
Brett....
Discussion Starter · #36 ·
Led Zeppelin....
Brett....
If only... mines a rev rotation also that came with my Concept One pully system. It's an Edelbrock # 8864
21 - 40 of 93 Posts
