1 - 2 of 2 Posts
I've been reserching the wiring on the 69 Camaro and need some help. If there is anybody out there that has an original harness or has their car apart where they can easily see the harness, could you respond to this post?
Here's what I need:
Which configuation do you have:
Firewall connector:
1. Two brown wires on one of the terminals of the firewall connector, (between the black wire and the small tan wire.)
2. One brown wire on one of the terminals of the firewall connector, (between the black wire and small tan wire.)
Parking lights:
1. Two brown wires on the left parking light.
2. One brown wire on the left parking light.
Battery Cables:
1. Black positive cable.
2. Red positive cable
Amp gauge:
Location of conection of the black/white wire. Is it connected where the 10 and 12 ga red wires are spliced near the voltage regulator and horn relay?
Right turn signal indicator (instrument panel):
1. Two dark blue wires on the right indicator light.
2. One dark blue wire on the right indicator light.
Left turn signal indicator (instrument panel):
1. Two light blue wires on the left indicator light.
2. One light blue wire on the left indicator light.
Light switch: (A)
1. Two brown wires on one of the terminals of the light switch connector.
2. One brown wire on one of the terminals of the light switch connector.
Light switch: (B)
1. Two white wires on one of the terminals of the light switch connector.
2. One white wire on one of the terminals of the light switch connector.
Body harness connector (instrument panel harness side) by parking brake: (A)
1. Two brown wires on one of the terminals of the connector.
2. One brown wire on one of the terminals of the connector.
Body harness connector (instrument panel harness side) by parking brake: (B)
1. Two white wires on one of the terminals of the connector.
2. One white wire on one of the terminals of the connector.
Body harness connector (tail light harness side) by left wheel well/trunk: (A)
Body harness connector (tail light harness side) by left wheel well/trunk: (B)
1. Two light green wires on one of the terminals of the connector.
2. One light green wire on one of the terminals of the connector.
If you're wondering why in the world I would need to know this, it's because I'm working on those full color wiring diagrams for Team Camaro members.
http://hawkpichost.com/ims/album.php?u_id=47kT1HB
I'm basing the diagrams off an actual harness as the original wiring diagram we have all grown to know so well has a few errors, at least based on a couple of wiring harnesses I have laying around.
Appreciate any help you can give me!
Larry
1 - 2 of 2 Posts
