Hi fellow Camaro lovers. I have been trying to identify a old Harrison cross flow radiator. It is the exact size of a 1969 Camaro, 4 row radiator. 23" long and 17" high. has a tranny cooler for A/T. The inlet (upper) neck is straight like most Camaro's, but the lower has a slight (around 45 degree) bend or curved neck that turns up very slightly. It has no brackets attached to it, nor does it look like it ever had brackets. The tag attached to the core reads either 98 8 or 8 86 depending on which way you look at it. The passenger's side tank (with the fill/cap hole) has an A, then a 3 to the right and above it and then an I or 1. Also, does anyone know of a radiator identifying website? Thanks and happy holidays
