Any thing can be installed, as for a direct swap it should work with out any major modifications, you will have to get the sending units for the gauges, from the donor car,Good luck
the connector(connections) for idiot lights is different for gauges(rear console) but you can change wiring around to make it work(or get connector from donor car?)i took guage panel all wiring from a 73 and going to install in a 70..(there was a posting on http://www.nastyz28.com page regarding wiring change(interior section) you'll have to dig for it but its there) good-luck...
70camaro(350)ground-up restification,350 slightly modified
