68 Base Camaro 355 Offy crossram Richmond Super Street close ratio 5 spd ivy gold 92K SoCal car
Main jets, according to Holley, have no effect on idle circuit. So I dont think thats your issue. Since its almost always too much transfer slot exposed double check that. Then try disconnecting PCV hose from carb base or whatever port its connected to and plug the port then see if mixture screws have any effect. Finally take your primary fuel bowl off and check your power valve, I would just repace it, probably a 6.5 is what you will find it to be. Holley stamps single number on flat of hex bade, 6 indicates a 6.5, 8 indicates 8.5, ect. Make sure you use the correct power valve gasket for the type valve you have. There are 2 styles, rectangular hole (referred to as picture window PV) uses standard round gasket. Small circular hole valve uses a circular with 3 standoffs designed on inside diameter. If valve is bad take carb off, turn upside down and if 1992 or newer carb make sure when built or rebuilt someone didnt remove the anti-blowout check ball. If missing you need to replace it to prevent damage to another new PV. If carb older than 92 Holley makes a kit toodify your base plate or buy a whole new baseplate with the blowout protection.• 1969 350/300 internally stock.103,000 miles
• Rebuilt 4150 Holley 600 cfm
• New points, condenser, coil, and cap
• Compression—all cylinders test 150-155 except one (#5) at 145
• Float height at primaries and secondaries adjusted to correct levels.
• No vacuum leaks detected
• DWELL 29º
• Timing 14º BTDC (I'm not 100% positive the distributor vacuum canister does anything. No change at idle with vacuum connected to canister or without. Is there a way to test this?)
• Idle 600 rpm in drive (engine will actually idle as low as 375 rpm—not well, but will run without dying.)
• Manifold vacuum steady 20 in park, steady 17 in drive while idling at 600 rpm.
• Ported vacuum 0 at idle
• Car idles smoothly, accelerates quickly without any lag or misfires, and pulls strong to the yellow line—best in years
• Exhaust still smells mildly rich, idle screw adjustment does nothing
I have not yet removed the carb, I wanted to do everything else, short of that, first. Using an isolated bright light shining down into the manifold thru the wide open carb secondaries I can see a sliver of light when primaries are slightly opened, but when tested, it appears that the primary butterflies are fully closed with the throttle at rest...but I'd like to try that test once more.
All that to say that everything appears correctly adjusted but STILL the the exhaust smells slightly rich and the idle mixture screws have absolutely no affect on idle or vacuum even when screwed all the way in.
One theory suggested is a damaged power valve, possibly from the previous backfires.
Any suggestions?
If no damage, all okay. Someone may have drilled out the idle feed supplies in your metering block. Mixture screws dont set the mixture, they only adjust the volume of fuel. The metering block has 4 supplie feeds, 2 for main circuit, 2 for idle circuit. The main body has air bleeds seen through top. The idle air bleeds and metering block idle feed restriction actually establish idle mixture. Sometimes guys try drilling these out to correct situation where someone is trying to use a street carb on a race engine richening the idle mixture. If thats your case a new metering block will solve this.
A short cut would be a brand new or Holley reburbished carb, about 60% the cost of a new Holley. But you know what you have and Holley makes them run and look like new.
