Everyone,
I have a idle vacuum question concerning a small block 350. It's a very typical old school small block. Basic specs are:
~10.5:1 compression
GM double hump "186" heads, with mild porting / polishing still 2.02 / 1.60 valves
69Z28 intake with a Holley 750 DP carb.
Lunati 40134 solid lifter camshaft, non roller.
Mallory Unilite distributor with the vacuum advance not connected, timing is 8 degrees initial and 38 all in around 3500.
1 5/8" headers with 3" collectors and 2.5 exhaust.
This weekend after reading a link on this site I decided to connect the vacuum advance on the distributor. The issue is that I don't appear to have enough manifold vacuum to activate the advance at idle. When I rev the car up and let it come back down to idle, now the vacuum advance is activated and I have a totally different idle RPM (way too high). If I lower the idle via the carb screw the vacuum advance drops out again and then the idle is too low. So I checked the vacuum with two different gauges and the engine only has 5" of vacuum at idle. would this be considered normal for a cam with these specs.
Adv Dur Dur @0.05” Lift Int/Exh LSA/ ICL Lash Int / Exh
40134 278/288 239/249 .517"/.543" 106/102 .018"/.020"
If so then I'll leave it alone and go without the advance as I have for a while now. If not I'll look for a leak. I did a quick carb spray check around the intake and didn't find any leaks.
Ray
~10.5:1 compression
Ray
