Hi guys,
I am preparing so the install will be more easy... I got today the first package, which is the PWM controller.
it is meant to be be installed with the aluminum support working as a heat sink, assembly this way. But I don't like it.
It is 1 3/4 " and I am almost sure I cannot install it inside the shroud. I don't like to install above the shroud. I found there is no other place because I kept my battery at the original location.
I called North radiator but they do not have a real technical service.
I am thinking of that assembly :
Any objections?
I am not going to drill new holes on the PWM box, I can locate reuse the holes for fixing. The plate will be drilled.
Depending on the room inside the shroud, I am thinking the wire connection point could protrude through the shroud, the plate would be fixed not using the bracket but just directly on the plastic shroud. I would keep the bracket unused as heat sink.
I'd like your opinions. Best should be to ask Carl Casanova himself
I think my idea works, and I could use some spacers / shims between the plate and the shroud to avoid the contact and get a small amount of air between.
Marc
