This is a hook up point on the fuse block on the inside of my camaro. Could I use it as a 12 volt source for my msd ignition and just cap off the resistor and yellow wire and run a wire from this IGN terminal through a grommet in the firewall to the coil? That would work would'nt it to give me a full 12 volts necessary for the MSD?
