OK I cant seem to find it anywhere. Anyone know how the IGN lug on the fuse box is powered? Mine doesnt seem to be alive and would like to get it fixed...
Im pretty sure that lug only has power when the key is turned to IGN. Try that once. :)
right... In any situation though Im getting zero volts. Accessory, on or crank.
IGN spade is on a buss bar behind the fuse panel.
It could be the bar is broken or ign fuse is blown.
Theres an ignition fuse?
Mine says 'stop' to the left of the IGN spade.. and it appears to be fine.
In a glass fuse appearance means nothing unless a meter or test light is involved. They often "look" fine but test bad.
Jeff
Discussion Starter #9
True and I did take it out and test. All my fuses are good and all my fuse connections are good. I guess Ill just have to find a different spot to tap switched 12v
