1 - 2 of 2 Posts
Before attempting to start the car, I just want to make sure all the wiring it set and the ignition. I have the non-hei distributor and wires all set and a coil. Is that all I need. What is all the other "stuff" you can buy for and ignition, "retard boxs" "delays". Is it nessesay or just for special application. Am I all set with what I got.
Tim
For originality the points distibutors are the only way to go. I cheated when I was still leaning that way and put an infra-red trigger system in the distibutor and hid the control module. I'm still using the infra-red but replaced the stock coil with an Accel super coil and Taylor spiro-pro wires. As far as using a retard module, rev limiter, delay box, etc. if you're just cruising and you're not running 12:1 compression you don't need em.
'69 RS Camaro
355 5-speed 4.11
1 - 2 of 2 Posts
