Hi guys, me again. What is the trick to removing the ignition cylinder from the ignigtion switch. Learning to put new words together tonight. Thanks again.
Going by memory here, but turn the switch to the ACC position and stick a paper clip(the bigger the better)in the hole. While pushing down on the paper clip turn the cylinder and it should come out.
67 Camaro SS Conv.
70 Challenger R/T Conv.
Gambler,
Provided your car is a 67-68 this is what you do.
Put the key into the igntion switch then insert a small diameter drill bit (or piece of wire) into the hole at the bottom of the key portion (bezel) and turn it to accessory, turn it alittle further past ACC and pull it out.
RAGTOP, Quick response we hit at the same time1
TONY
67 CAMARO R/S CLONE, 355/turbo 350, 200hp NOS,12 bolt,etc...
[This message has been edited by idoxlr8 (edited 02-08-2001).]
Discussion Starter · #4 ·
thanks guys for the quick response. That is why I love this site. Still working on the ignition. Will keep you posted
will this work on a 71 camaro?
What if you can't get your ignition switch to go into the accessory position?
Justin
-1967 Camaro SS350
www-student.furman.edu/users/j/jtrauner
