Everything is hooked up and ready to go on the new 502, but...I get NO power(lights, fan, etc.) until I turn the key to START. It still doesn't crank, but I have no power anywhere until I turn the key all the way.
I jumped the starter terminals and the starter engages, so that's a detail at this point. I have the full MSD 6AL ignition, coil, and distributor.
I've been brainstorming and I'm stumped...HELP!
Mike
Discussion Starter · #3 ·
No, didn't do anything with the wiring inside.
Pulled the 454 and dropped in the 502. The starter is different than my old one, this one has 2 large terminals, 1 + terminal, one small terminal(ignition/start I assume) and 1 terminal with a jumper going to the starter. My old starter was 1 large + terminal, and 2 small ones, solenoid and resistor I believe. I have the battery hooked up correctly, and one of the other leads hooked to the same terminal, and the ignition lead hooked up to the small terminal.
I tried other combos and this is the only one to give me ANY power, but it's ONLY with the key in the "START" position.
I'm losing my mind over this, this thing should have been fired up last night.
Discussion Starter · #4 ·
Well, I pulled the MSD distributor out and put the HEI back in and disconnected all the MSD stuff. Hooked the battery cable to the big battery post on the starter, hooked the purple wire to the solenoid, and hooked a wire from the battery post on the starter to the BATT connector on the HEI and still have nothing. No power to any lights, fan, etc. key on, off, or start. I have no clue where the problem lies.
I've never had any starting/electrical problems before I pulled the 454 out. I did mount the battery in the trunk and have the + cable running along the underside directly to the battery terminal on the starter.
I'm apparently no rocket scientist when it comes to electrical, but what makes the dome light, headlights, etc. work? I'm completely exhausted, mentally and physically, haven't even slept yet and I'm completely out of ideas.
Anyone with any guidance, please let me know what you think about this and what I need to do to get her fired up.
Thanks in advance for any and all replies
Mike
Clill is right... there is a second positive lead from the battery that runs around the radiator support over to the horn relay. With this attached, you will have horn and lights without having to use the key.
I have my battery in the trunk, so I just jumped this lead off my alternator, which in turn connects to the positive battery terminal.
Discussion Starter · #7 ·
Oh my GOD, do you guys rule!!! Just hooked a jumper wire from the battery + terminal in the trunk, along the floor to that junction block(it was just a test), and the headlights came on as soon as I hooked it up, go around and hit the key real quick...it's dry/new. And the starter kicks.
THANK YOU!!! THANK YOU!!! THANK YOU!!!
If it sounds as if I'm overly gracious, not a chance, this was literally driving me crazy...like for 2 days, don't know WHY I didn't think of posting as soon as it became a problem.
I'm heading out to fill her with coolant and oil and fire her up. NOW I'm getting excited, initial fire up of the ZZ502!!!
Thanks a million again to you guys, I truly hope I can return the favor some day...just NOT in the electrical department. :p
Mike - 68SS454...a.k.a.68SS502(hurry up DMV)
Discussion Starter · #9 ·
It's ALIIIIIVE!!!
Thanks again for your help guys, I've driven it, but it was dark and didn't want to go far. Only around the neighborhood a few times. WOW, that's about all I can say at this point. Can wait til she's broke in...
Mike - 68SS502
Time to update the profile, eh?!
454, TH400 w/4,000 RPM stall and shift kit, 12-bolt posi w/4.11's.
