Got a 67 rs camaro, everything from the alternator, regulator, battery, relays, starter& solenoid are new and have been retested. My problem is that sometimes the car won't start, not even crank the engine. I can hear the clicking on one of the relays. Once I put the jumper cables it starts right away. I have checked the wiring and everthing seams to be o.k. I can start the car by bypassing the ignition under the car between the starter and solenoid with s screw driver. Getting to be anoying Any suggestions would be appreciated!! Thanks
Clean the battery cable clamps and the other end of the cable as well. If they are the clamp-on clamps, replace the whole cable with the molded clamps and get at a minimum, #2 AWG cable.
Once started, check charging voltage at the battery posts. Compare this reading with the Alternator terminal. Should be within a 1/2 volt.
There is a buss bar on the horn relay with two big red wires, clean this connection, and over by the battery on the radiator support, is a junction block,, clean this connection as well.
Ground the body to the engine and the engine to the battery.
If this is happening after the car has sat for awhile, you may have a electrical drain problem. Otherwise, You are probably either experiencing a voltage drop on the S wire and/or your ignition switch may be bad ... You are obviously getting some power since you hear the click. If you can't find the culprit, you can consider using a remote solenoid. They have been discussed here many times before and are easy to connect. Some people use them to address heat-soak problems. The remote solenoids work because they can switch with as little as 7 to 9 volts, but still provide a full 12 volts to your starter.
