1 - 8 of 8 Posts
I have looked at every paper I can fine on the removal of the ignition switch on my 69 Camaro I have taken off the Steering wheel but I don't see the slot that I have to press to release the switch. So what can I do. Here is a picture so you can see what I see.
The slot is there where it should be. Just filled with some metal from casting. It will punch right out easily
So take a screwdriver and break into that slot that is covered up? is there anything else I need to do?
Yes, punch through the slot circled in your picture. The release is behind that slot and has the same shape.
Ray
1 - 8 of 8 Posts
