1 - 2 of 2 Posts
Who makes a good set of hei ignition wires..also I'm running 2457 headers.. Should I go straight boot, 90 degrees or 45 degrees..
Any info would be appreciated.. Thank you
Have used 8mm top gun stainless spiral wound for the last 25 yrs...near 200,000 miles, only resently on a new set.
I make up my own.
I use both straight and 90 degree on the plugs.
Each side come off the cap laind out as per each side in a flat loom with clips.
Ther rear 2 HT leads on each side cross just before going to the plugs out of sight.
1 - 2 of 2 Posts
