1 - 20 of 28 Posts
I have a 68 with a short Weiand pump, small but very thick Modine radiator and a 454. I have been sinking into despair about the lower hose. I went to OReilly and bought 5 hoses thinking I could find a couple to hack into pieces and use with a piece of pipe to make a hose that would fit. Not much luck. Been looking over the internet, thought about going to my exhaust guy for some kind of weirdo bent pipe I could attach the rubber end pieces to.
Went to Auto Zone last night and bought 4 likely candidates and I'll be darned....one bolted right up after trimming 6 inches off the radiator side.
I'm so happy! The motor is now finished, got 5 gallons of water in it and ready to fire off tomorrow after work. I'll have a couple weeks to tune and fix anything before my club's Dyno Challenge.
I was really beginning to think the lower hose solution would end up costing way more than it should and take weeks to solve; even to the point of buying another radiator.
There is so little room for a hose to fit. The one that did is a Dayco 71215 for a ford truck.
I am posting mainly in case anyone else needs a weirdo hose to fit. Also because I am so very happy to have a major trouble spot taken care of.
The forum fan patrol is going to bust you for that flex fan with no shroud... :grin2:
Don
I'd stand way away from that fan while doing a dyno test ifin I were you. Flex fans are downright dangerous at high rpm.
Nice find, and good innovation.
Looks nice. Be sure in writing part number in your log book for future use.
Congrats on the hose find :beers:
I had an issue with a swap to electric WP. Ssssooooo I cut and taped pieces of my old ones together, then off to the parts store....Lucky for me, an older guy seen me come in and just walked me back to the hose section, told me good luck, any problems shout.
Didn't take too long to find what I needed, and yes, a little trimming, then perfect ;)
Discussion Starter #8
That flex fan is a baloney slicer. It has my respect and then some. I'll get a shroud later.
Cranked it up, base timing, ran and watched the water temp and it is over heating big time. The thermostat is definitely opening, the radiator is passing water but not in the volumn I'd like. Heater hoses getting hot as is the by-pass. When I shut it off the radiator does its volcano impression. Life is fun.
Running that sucker with open headers in the garage was a trip.
I have a feeling that several year old Weiand pump is underperforming.
Tomorrow I will re-torque the heads and take the water pump off and inspect it again.
Back in my youth I ran without a shroud and had constant overheating at idle. Added a shroud and the problem was solved. Been a believer in the importance of fan shrouds since.
I’ve got a shroud and clutch fan I pulled off my wife’s 69 factory AC car that you are welcome to.
Don
Remember the fan should be half in, half out, for the best air flow performance ;)
Has anyone mentioned that flex fan yet? >:)
On another note I believe my L6 250's lower hose was just about identical to that when I was done. Had to go through the same stuff. Took about 4 tries to find one that worked. Luckily I had a great relationship with the guys at AutoZone and they let me take several to try.
Discussion Starter #13
Don
That is a very generous offer Don and really appreciated. I'm in Mesquite, east of Dallas a little bit and that's quite a drive though.
I started to put a clutch fan on this motor but this radiator is so short I had to go to a 16" flex fan to fit so I didn't chop radiator hoses. I picked up this Modine radiator 20 years ago I bet. It has 4 one inch rows. I will put a new water pump on the motor tomorrow and move the fan an inch closer to the radiator. The only fault I can find is that the water is not moving through the radiator very fast. Kinda dribbling through the rows. If this doesn't do it then I'll have to change radiators. And get a shroud. And maybe some electric fans.
Discussion Starter #14
Old water pump was most of the problem. But water still isn't passing through the radiator like it should. Temp ran up to 200 then apparently the thermostat opened for it dropped to 150 then stayed under 180 for quite awhile until finally running up to 220 and staying there. That flex fan and lack of shroud is not moving much air.
Water still isn't running through the radiator like it should. Wondering if most of it isn't just going through the bypass. Gonna pull the thermostat tomorrow and see what happens, maybe try to fit a clutch fan I've got laying around.
I still haven't been able to road test it. No plates, inspection, mufflers......sounds bitchin' with the open headers though. Very crisp.
Mickey,
Beautiful engine! Open headers in the garage - wow, how's those ears? This comment is off topic, but I noticed in one of your photos you've got your vacuum advance tied to ported vacuum. There has been a lot of discussion over the past year here on the forum about the advantages of full manifold vacuum to the VAC. As you fine-tune that new beast, switching to full manifold vacuum might be something to try at some point. The switch from ported to manifold sure made a big difference in the drivability of my car. Apologies for drifting off your intended topic.
I have never understood why water pump flow rate was a significant concern. The slower the flow the greater the temperature drop of the coolant will be. So I see no issue unless the coolant flow is so slow that the coolant reaches ambient air temperature before it passes completely through the radiator. Faster flow means less temperature drop of the coolant on each pass, but obviously you make more passes so the net cooling effect should be similar. At least this is my thinking. Looking forward to someone schooling me.
Don
68 RS L30 AA 749
Good question, Don. I've always been led to believe cross-flow radiators are more efficient than down-flow because the coolant travels slower as you describe....
take a 81/2x11 paper and put it in front of the rad see how much of a pull that fan has and where. if it doesn't stick to the rad like goose **** to your shoe put a shroud on it :p
Reactions: dhutton
The people with backgrounds/degrees in thermodynamics...including water pump people like stewarts....all say faster the flow the better. Slowing it down of no value. Keeping fluid in the radiator longer doesn't dissipate more heat in comparison to the extra time it would also spend in a hot block absorbing heat. Lots of info on this already. Don't get mislead.
1 - 20 of 28 Posts
