1 - 13 of 13 Posts
Was talking with some camaro guy's this week.
I noticed they all had HEI's, (a group of 3 together) and they didn't have to smash the firewall in.
Told them about the discussions we've had about some camaros having the clearance and others not.
They said you have to swap the mounts side for side. And the lip has to be ground off or they won't sit flush with the frame.
Ahhh, I seeeeee.
Just thought I'd pass that along.
Steve
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
69 4X4 suburban 350,4-sp
73 3/4 ton 454/400
Stevo Camaro's Toy
Our Muscle Cars
My 67 has the aforementioned "modification" about switching the mounts. I did not do this mod, the guy I bought the car from must have. However, he didn't grind the lips off the mounts, though, so the lip bent up when they were reinstalled.....stupid!!! Plus, you will have to modify the transmission crossmember since the engine will move forward about 2 or 3 inches by flipping the mounts....guy did a crappy job on mine. But, I have plenty of clearance behind the distributor, although the guy NEVER INSTALLED AN HEI!!! I wonder how this affects the handling of my car with the engine being a couple inches more towards the front of the car than it should be????
Any thoughts on the handling issue (esp. David Pozzi???)?? The more I think about this, the more I wonder if this could be the source of some of my car's high speed vibrations........
Justin Traunero
[email protected]
-1967 Camaro SS350
http://156.143.134.136/default.htm
[This message has been edited by jrt67ss350 (edited 04-23-2001).]
I think there are different mounts for our cars. I have shared this before, a friend of mine has a stock 307 '69 ragtop. His engine sits 1 1/2" - 2" closer to the radiator than mine... If I recall there are 2 mounting positions in the frame for the crossmember also. I read somewhere that moving the engine back is good for handling... It distributes the weight better through the whole car..
...Dennis
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
"The Club"
My 383 sits on original six cyl mounts. I used a hammer on the firewall for clearance when converting to HEI. I didnt really do that much, it's not really noticeable.
Our cars are already a little nose heavy...moving a 500 lb engine 2 to 3 inches forward can't be a good thing.
My69gofast is totally correct, what people do when racing is is move the engine back for more traction at the rear wheels. But regarding the info Steve has brought to light, I have a friend who has an HEI and is willing to install it. He doesn't care much about handling, I don't think he runs his car at more than 50mph anyway. If it works is a good hint.
What about electronic distributors like Accel or mallory. They seem to have smaller bases and caps than a standard GM HEI distributor. Has anyone tried one of these with any success???
69 RS 350 (under construction)
98 GMC Sierra 1500, Z-71, X-cab, K&N
No measureable effect on the handling.
There would be problems with a four speed shifter fitting the console, etc.
A long time ago I calculated moving the engine on a friend's sprint car, left and right.
You need to move it a bunch to make any substatial difference. Like maybe 6 inches or more.
And even then, on a Camaro moving something smaller like the battery from front to trunk is equal to moving the engine 15" back!
which would you rather do? move the engine 15" or the battery to the trunk?
I'd rather go with a small body HEI or swap a HEI module into an early point distributor.
I've got a couple of early corvette "mag pulse" distributors with tach drive that I use in the Lola. It triggers the MSD unit I use.
The mag pulse parts will swap right into the early point distributors and you could use an HEI module to trigger it or any MSD etc.
the problem is the mag pulse parts are getting hard to find, and expensive.
I've seen photos of the distributor Dave Ray does and that looks darn good too.
I have to put a warning in here that I recurved an HEI for my truck and it was the first HEI I've done since I got a distributor machine.
I had to grind hell out of the weights to make it advance quick enough and do a LOT of work on it. If I were doing them for a business, I'd charge triple to do them!
If anyone uses the HEI and just puts an advance kit into it and expects it to work like doing an early point type distributor, they will be dissapointed. This is definately a distributor that needs to be professionally set up.
David
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350
Can Am Vintage Racer
[This message has been edited by davidpozzi (edited 04-25-2001).]
I have an Accel in my 69 small block. It's all electric, including advance. No vacuum. Clearance is fine and the car runs great. This is with their 300+ ignition module. I can pull the model number if anyone's interested. The specs are 24 degrees advance ( at crank! ) in by 2500 rpm. I run 12 initial and have an M-20 with 4:10's in a high compression 355. Love it.
have heard some not so good things about the mallory unilite however mine works great and was one of the easist things ive ever put on the car.
I use hei in my 69 with no clearance problems.I have vacum and an accel on top. Its on a 327 with a m-21.
David,
You've got me hands down when it comes to suspensions and handling, I would have thought moving the motor back a few inches would have changed the cars center of balance for a positive effect on handling.
I must say I too am impressed with the overall quality of the Dave Ray product. I just received mine yesterday and don't have it installed yet but it looks mint! His documentation is also high quality... I will report on function when installed.
...Dennis
"The Club"
1 - 13 of 13 Posts
