1 - 2 of 2 Posts
89 z-28 350 tpi, won't run unless primed first, runs fine after, fuel pressure fine, 12 volt at injectors. any suggestion
It might be a bad fuel pump relay. I think the oil pressure switch takes over after startup.
Do you have the OK fuel pressure when the key is first turned on before starting the engine?
David
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
1 - 2 of 2 Posts
