I'm in the process of converting my (previously non-original) 1967 inline 6 camaro to a 396 big block. I used the correct motor mounts and engine brackets during the install. Now at the point I'm trying to bolt in the correct original exhaust manifolds that I hunted down, the driver side just won't clear the power steering gearbox. Has that been a problem for anyone? Any solutions out there from the greybeards?
I've already got some desperate answers going through my mind: change to headers, get rid of power steering, roll the car off a cliff, .......:confused:
Post what engine and frame mounts that you used and the part numbers on the exhaust manifolds.
The Big Block engine is supposed to be offset 1/2" to the passenger side. If you measure from the carburetor stud to each fender, there should be a 1" difference in your measurements.
Also, make sure that your transmission crossmember is correct by moving the Transmission (and engine) 1/2" to the passenger side and forward by 3/4".
I specifically bought the big block motor stands from Ecklers, so I'm confident about those. I did get out the tape measure and tried the trick you mentioned, and sure enough the engine is nearly an inch offset toward the passenger side.
I'll try unbolting from the driver side motor mount tomorrow and jacking it up just a bit to get the manifold on. The manifold does have a big depression in the area where the steering gearbox corner goes, so once it's on, I'm thinking it should settle in and clear by a little bit.
The casting numbers aren't real clear on the manifold, but it looks like 3909879 or 3808879.
How about that transmission crossmember ? If you don't have a big block crossmember the engine will sit crooked and your exhaust manifold will not fit !
Good point. There are 3 transmission cross members for the first generation Camaro. BB 4 speed, BB with a TH400, and one for the rest. The BB cross members transmission mounting holes are offset towards the passenger side as well. What transmission are you using?
I have a Bowtie Overdrives crossmember for the 700R4. I don't recall it saying anything about it being specifically for any type of motor..... I'll crawl underneath tonight to see if there's any adjustment I can make pushing the tail of the trans toward the passenger side of the car which in effect might create clearance for the exhaust manifold.
Discussion Starter #8
Well, Bruce's trick worked. It took me about an hour of trying to realign the motor mount hole back up enough to get the bolt back through, but it finally did. After the exhaust manifold went on, then the motor settled back down, it ended up having lots of clearance. Like over 1/2". It's because of the big depression-type of indent they cast into the exhaust manifold right where the corner of the power steering gearbox is closest to it. Thanks everyone.
Many places that sell transmission crossmembers do not even know that there is a difference between a crossmember for a Big Block and a crossmember for a small block.
I am betting that your crossmember is not right.
The Big Block piece should move the transmission mount 1/2" to the passenger side and 3/4" forward from the small blocks location.
Even if you finally got it all bolted together it doesn't mean you are home free. The engine is sitting crooked, which can cause vibrations etc. The other thing is that you are stretching your transmission case 3/4" ! You can expect cracked transmission cases etc.
To check if yours is correct, measure from the side of the subframe to the output shaft centerline on both sides. It should be just like the carburetor stud measurement, A 1" difference in your measurements. This is a 1/2" offset !
