1 - 20 of 21 Posts
hey there I got the swap done except for the intake/carb and exhaust so far, here is my question
how do u adapt the gas pedal lever next to the firewall to the carb??
How do i make the powerglige kick down rod work as it is sitting on the outside of the valve cover???
Where do I put the coolant temp sensor???
How do I connect the oil pressure switch beside the distrib to the harness is there a adapter to get as I have a 1 inch high nipple with a peice of copper hard line cut off???
i have swapped a 67 camaro motor form a inline 6 to 327 sbc motor, also the tranny is stock that was on the inline 6 2 speed powerglide. , intake is a edelbrock performer, and the carb is a edelbrock 1406 thanks
anyone with info can email me or add me to msn [email protected] thank you in advance
to be correct.........
you need to get the powerglide kickdown linkage.there is a bellcrank that bolts to 2 bellhousing bolts
and then two rods.see below....
these are going to be tricky to install if you have already installed the engine and trans..................
http://cgi.ebay.com/ebaymotors/powerglide-kickdown-linkage-67-68-69-Camaro-chevelle_W0QQcmdZViewItemQQcategoryZ33727QQihZ015QQitemZ250202735316QQrdZ1QQsspagenameZWDVW
you need the v/8 throttle linkage. the 6 cyl used a cable....the v/8 uses linkage.see below
http://cgi.ebay.com/ebaymotors/1967-1968-1969-Camaro-Accelerator-Assembly-67-68-69_W0QQitemZ360009858280QQihZ023QQcategoryZ34206QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
well as far the pedal linkage goes that is what i have at the end of the firewall, it is a lever and it kind of lines up with the valley so i am not sure if i need to get that but the other piece is it what is required to make the kickdown cable to work so the bracket bolts to the bell housing thanks or can i get that from any 350 and and is there any other cars that will fit this thanks or a different setup i can get from the local junk yard
I took the 6-cyl carb linkage, cut it in the middle, then doubled it up to the carb and pedal and welded the two pieces together.
The P/G kickdown linkage shown is SBC V8 only, the only one to work. See any P/Glide equipped full size car, truck, Chevelle, or Nova for linkage.
Coolant temp sensor goes on drvr head between 1 & 3 cyl.
Oil pressure switch from 6-cyl will fit into V8 block by the distributor, just coil up the lead and tie up with a tyrap by the firewall.
Same with ign coil power lead.
ok that is great help guys but i am still uncertain as to which linkage goes to the gas pedal by the firewall, cause i have a large lever looking thing there, and i think the 6cylinder one might work, do u guys have any pics or part numbers of this stuff and also the kickdown cable, can i snag it from any other motor?? or a wreck yard
The carb linkage would be the one going from the firewall to the carb, direct line. As said, I used the same rod, cut in half and welded it together. However, if you search our sponsors here, I'm sure someone will have the correct V8 rod.
Only a Powerglide equipped V8 vehicle will work for acquiring the kickdown linkage and it is not a cable, only the throttle control was/is a cable. Your present 6-cylinder trans kickdown linkage is a single long rod from the carb to the trans, approx 4 ft long. This rod will not work for a V8.
can u give me some pointers as to where or what cars, will fit and have that kick down rod on it and do i need to remove this 4 foot long rod and replace it with a whole new one or just cut this one off or ???, also now that u r saying the gas pedal lever is to be connected to the carb by doubling the rods and that should go, do u have any pics u can email me thanks [email protected] or are u on msn messenger add me
The present 6-cyl kickdown rod will not work on a SBC V8. You can look at most any 1962 to 1974 GM car/truck equipped with a SBC V8 and Powerglide for the linkage set-up shown in wagonman's post. The heat shield shown may or may not be in place. When you unbolt/remove the V8 linkage, take as many items, including the linkage studs, the linkage connects, including the clips and bolts. Miss one item and attachment will be futile. Make a diagram or take good pictures before removing the linkage for future aid to installation. You will need all the info to make for a good install.
The gas pedal to carb linkage may have been a cable.
If a cable, transfer the carb cable stud from the 6-cyl carb and install it into the V8 carb throttle arm in the same hole and attach the gas pedal linkage.
If the linkage from the pedal to the carb is a rod, the rod has a 90° bend at one end, this end hooks into the pedal rod on the firewall, the other end is threaded, and gets installed into the carb bushing (be sure to transfer this bushing from the 6-cyl carb to the V8 carb), cut the rod in the middle. It will be physically too long. Hook both ends of the rod to their respective places. Pull the pedal and 1/2 of the rod forward, you want the pedal off the floorboard, clamp both halves of the rod together with locking pliers and weld the two cut pieces of the rod together.
Or, probably easier, look through the sponsors catalog for the correct V8 carb linkage rod. Maybe get one from any Nova/Chevy II/Camaro/Firebird. Trucks and full size cars may be too long as they have longer wheelbases.
Discussion Starter #10
hey guys i am still so confused how this thing connects the tranny to the intake does anyone have any pics that would really help and is the gas pedal from the 6cyl gonna work on a v8 motor, i mean the little arm by the firewall, it looks tight unless that is how it is suppose to be?? pics please thanks
Discussion Starter #13
wow that is some nice pics u guys r awesome but here is another question if i change the tranny all together to a th350 or 400 will i have to change the shifter in the car, cause i want that to look stock is that possible since it is so hard to find the powerglide peices in my area. thank you what u guys think the motor is a 327
Thanks. Besides the PG, for a 327, the tranny choices are TH350, 200r4, 700r4. A TH400 would suck the life out of the engine.
A TH350 uses a kickdown cable and the cable is mounted very differently, the 200r4 fits in the same spot as a PG, but uses a TV system. The 700r4 uses the TV, but is a little larger than the 700R4 and the tunnel needs to be enlarged and the driveshaft shortened.
You can use the stock shifter in all transmissions, but would need to change the detent plate so the gears match. Also some brackets on the tranny how the shifter cable mounts will have to be changed.
Discussion Starter #15
ok well what u suggest is the best application for the tranny as all the trannys are available here, and i would like to do this the most easiet and cost effective way, please that is bolt in type without comprimising the stock shifter and what would i need to mod that part of the shifter thanks
You really need to do some research on "shiftworks" and trans rebuilding shops. For a rough outline:
use a PG when number matching is required $500-$1000
use a TH350 if you want better than a PG, but want some factory look $500-$1000
Use a 200r4 if you want good performance and gas milage, you dont care about numbers or originality and your rear gear is 3.31 to 4.10. aftermarket TV systems only works with 4bbl carbs. $1200-$2000
Use a 700r4 if you want good performance and gas milage, you dont care about numbers or originality and your rear gear is 2.73 to 3.42. aftermarket TV systems only works with 4bbl carbs. $1200-$2200
Discussion Starter #17
well i can tell u this that the car is all stock and i am not sure what is in the 10 bolt rear end as it was running behind a 250 6cyl with a 2 spd powerglide, what u suggest cause i did notice on the highway the car dragged and I was in the slow lane hahaha, so what u suggest as this is just a weekend car, and i want only a little performance, so let me know the only thing is i want the stock shifter look, whatever u suggest will be appreciated thank you once again
Discussion Starter #18
I have another question about the paddle for the gas pedal on the firewall, mine is a long 6 inch flat bar and it does not look like it will line up with the carb, is there another part that i need to change it to, thanks any pics or part numbers
1 - 20 of 21 Posts
