1 - 8 of 8 Posts
I have a question about removing the lower hinge plate mounted to the door shell. I need to do some repair to that corner and there is a lot of rust to deal with. Has anyone removed the hinge plate from the door to clean up rust and weld it back in? It wouldn't surprise me if there's a lot of rust between the plate and the shell. I can find most of the spot welds. My plan would be to drill 1/16" alignment holes to get it back to the proper place. Drill out the spot welds. Media blast. Do the repairs. Paint and reweld.
Wood Door Automotive tire Helmet Automotive wheel system
1967 RS Camaro / 1968 RS Camaro
Morning Magnon, about your removal of the hinge plate, making locator holes seems like the best idea, if you don't end up replacing metal in the process. In addition to making the locator holes, I would take measurements from know position on the inner door structure.(ie top measurement from top hinge plate and inner structure to a known point on the hinge plate you are removing, doing this assures you if there is an "OOOPS" somewhere you are swearing at yourself.
This is what I did on my 67 that I am resurrecting, this thing is FULL of rust and I have replaced copies panels and structure.
Discussion Starter · #4 ·
Thanks Henry. Will do about the measurements. So many photos with measurements! I have to keep a written summary of critical measurements and a date log of what I was working on just to find the photo.
Quite the tear down on your 67. I still need to deal with the cowl window area. Just completed the main core of the car. Rockers, frame rails, floor, trunk. I want to hang the doors before tearing off the quarters and wheel wells.
Hood Motor vehicle Automotive tire Bumper Automotive design
· Premium Member
When you drill out the spot welds the underlaying metal will be scratched. You can use the scratch marks to realign the pieces after sandblasting and painting. Just weld the drilled out spot welds back closed.
Automotive tire Gas Wood Automotive exterior Bumper
Fixture Bumper Automotive exterior Gas Wood
That is exactly what I did, I kept a separate note book with the area of the car I was working. I'd say you pretty much have most of the hard stuff knocked out. That white primer sealer looks really clean . I worked from the front of the car (Firewall) to the rear and left the floor and the roof skin for the very last pieces to get welded back in.
The roof skin and quarter panels came off first, then the roof skin, but as I was thinking the roof structure had some serious rust issues and that's kind of where I was forced to start, plus that where I got the idea of taking measurements, just for the reasoning, the floor board was so far gone it was too late to put inner supports on the inner portion of the car, lucky for me I put the car up on jack stands, leveled it and that's where it stayed until all of the sheet metal work was done. A key element is making sure the car isn't moved, but I think from the looks of your pic above, you already know that. LOL
Its also a very good idea to have the doors on the car when you hang the quarters, although some of the sheet metal out there it really doesn't matter cause its so dorked up you end up massaging something to make it fit anyway. I fit both quarter panels the trunk filler panel and the rear window filler panel all at once to make sure I didn't have any major fitment issues, (all the quarters/tail panel and filler panels fit wonderfully together by the way) use copius amounts off zip screws and various size vise grip clamps to hold everything in place before your final weld phase.
Are you going to go with mini tubs or are you going back to original? Just curious. in the picture you can see the gap from hell on the passenger door, it is the panel itself that fits like that, so I will end up welding in some filler material to take up the gap, the inside of the door fits perfect, the quarter panel was just not formed properly in the mold when it was made, but this is what you get to look forward to when you hang your quarters.
Added another pic of the well fitting fenders also, QUALITY, just wonderful Quality!!
Discussion Starter · #7 ·
Years ago I changed to a triple leaf spring and then a 68 posi and I’ll stay with that. I’m so far down on the learning curve, tubs and that path seemed too much for me. The primer I’m using is SPI gray and black for underneath. First thing I did was build a jig from the plans posted in the forum which has been great.
I bought 2 original gm 68 quarters over 25 years ago at a swap meet, so I hope they’ll be better than some of the metal available today. Will need to weld up the side light holes and vent inside the door opening which the 67 didn’t have. New metal for everything else out back except the package tray, hinges and trunk lid. After skinning the doors and a hinge rebuild, I’ll mock it up as you did with the doors. For me it will probably take until next year to be at that point.
Keep banging away, I'm lucky to finally be retired after plugging away at it for over 40 plus years, so now this is my NEW Job that keeps me actively doing something I really actually enjoy.
If you have any questions just leave a comment on my 67 Camaro resurrection page and I should be able to help you out.
1 - 8 of 8 Posts
