The clips have a prong that will poke into the gromet in the hole in the door. Hold the clip by the prong and you will see the other end is made to have the door panel slid into it or more correctly it slide onto the door panel. There are cut outs in the back of the door panel that allow the clips to be mounted onto the panel. If there is a round hole it allows for adjustment of the clip so the panel lines up on the door. You'll have to eyeball placement before popping the clips into the door.
Here's a pic of them installed on the panel.
go2fast...How did the velcro work for you. Thats a great idea.
