The instructions call for a wire that gets hot when the ignition is switched on. What's the best location to get power? Should I splice a wire or plug into the fuse block. Please be specific with your answer. I apologize if I put this in the wrong forum.
TIA,
Anthony
The resistance wire comes off the ignition block or plug, I would not use that terminal, but use the keyed and fused terminal off the fuse block. I did. To me , this small red wire is basically feeds internal MSD box to close contacts for the larger red wire for fire. You need full 12 volts here.
the resistance wire is the cloth covered wire that is connected to your + on your coil.
you must remove this wire from the engine harness plug (you wont get a full 12 volts if you use it)
and solder a wire to that terminal on the engine harness to replace the resistance wire.
just connecting it to any keyed wire will cause problems (I fried a wire doing it that way)
GM intended that the igniton wire is in that spot for a reason and it will be evident once you look at the ignition wires which are 12 ga pink wires off the ignition switch in the steering columb.
The original harness uses a white fabric covered wired to supply power to the + terminal on the coil. It was in the engine harness, and ran from the bulkhead connector to the coil.
In a lot of cases, this wire got cut, removed, or bypassed when someone converted to electronic ignition.
If you can't find it, you can run a new wire from the IGN terminal on the fusebox.
Do not use the ACC terminal, as this is not hot in "start"
69 wiring diagrams are here: http://www.camaros.net/forums/showthread.php?t=93576
