1 - 20 of 20 Posts
I'm having trouble figuring out how to get the headlight bulbs in the buckets and have them turned the right way... not aimed... installed in their buckets.
The bulbs have 'tabs' that are supposed to fit into the adjustable buckets so that they're turned the right way... rightside up so to speak. I'm assuming the word General Electric and other numbers go rightside up?
When I do that, the bulbs are turned sideways which makes the light shine the wrong way, even if I aim them. The high beams point the wrong way, which tells me the bulbs aren't oriented properly. I'm guessing the slot in the center filament thing is supposed to aim down when the bulb is in right?
The brackets that mount to the core support can only go on one side, and can't be mixed up, correct? I went by "the book". Then the adjustable bulb buckets attach to them. If I turn the buckets around, or swap them to the other side, the tabs for the bulbs STILL won't be in the right places to mount the bulbs! They only mount to the brackets one way.
What am I doing wrong? Are bulbs car specific? I might have the wrong bulbs.
Joe, I had a little bit of ?? when I was setting mine up. I cannot remember what I did to make them correct, sorry. I think there were L & R buckets. Take the buckets out of the brackets and fit the bulbs and trim rings in the bucket 1st, then see if you can install them with the GE words reading correctly. I know the brackets are different left vs right.
Discussion Starter · #3 ·
Yeah... the brackets AND the buckets are side-specific.
I'm thinking that the bulbs I have are wrong or something because the 'tabs' on them do NOT fit the indentations in the buckets. I just turned them to what I thought was the right orientation and tightened the rings down for now.
Bulbs usually have 'TOP" on the glass. At least the lines are horizontal.
Could it be defective bulbs?
Maybe the bracket the bulbs fit into have the tabs in the wrong place? Old one to compare, or another picture?
Aiming headlights is easy.
Preliminary: Proper tire pressure, half tank of fuel, empty trunk except for spare tire and jack, drvr and pass in interior.
Measure from the ground to the center of the grille and transfer to the garage door/wall with tape.
Measure from the center grille to headlamp center and transfer to garage door, both sides and mark tape.
Mark with tape, a horizontal line 2" under lamp center above step. Place a tape +, this lower horizontal line/+ is the new center line/spot for the high beam.
Align a carpenter's square and string from the center of the + to the center of the headlamp with the headlamp 25 feet from door.
Adjust headlamps accordingly.
Discussion Starter · #5 ·
Actually I have two different bulbs... neither fit the buckets. One bucket is an original (original to what, I have no idea... it's OLD) and one I bought from NPD, but the old one is the same as the new one so it must be from my Camaro.
It's just one more thing on this car that's tweeking me out.
Joe take the one in the picture and put it on the other side with the notch in the center hole up , that also puts the angled adjustment screw hole on top .see if that works
Yes thats where mine are , if you look in the AIM 12A3 the bulb ,bucket and ring are already assembled . The ring is stainless steel and the extra one i have has scratches and the edge is marked from the spring .
the headlights go to the ftont, not the back yard for a bunch of drunks, looking for
the (Star Ship Enterprise), yea I had to go here.
1 - 20 of 20 Posts
