i have a 69 ss camaro with a 454 with an auto 350 turbo in the floor and the gauge package and the dash carrier was changed to one without the tachometer, so i put a dash carrier in with a clock and a tach.unfortunally i lost the wiring diagram for the tach. i have the tach put in the dash carrier and have the wiring harness. it has one plug which i think goes to the dist.( HEI) and i think a ground wire. then it has two more plugs or connectors attached to the same harness, then it has a seperate wire with 2 funny ends on them. Where do the 2 plugs or connectors go and the seperate wire with the 2 funny ends. would they plug into the main wiring harness somewhere? i just don't know about the single wire with the 2 funny ends. or maybe they don't to be hooked up at all. ANY AND ALL HELP WOULD APPREICIATED. THANK YOU IN ADVANCE.
[This message has been edited by jimbird (edited 04-29-2001).]
<BLOCKQUOTE>quote:</font><HR>Originally posted by TOMSTV:
There are 3 lines to run the tac.
black--ground
red----power & lights
green--to negative side of coil
hope this helps
<HR></BLOCKQUOTE>
Thank you Tom i will go and try this. Jimmy
When you say "Power and lights", where does this lead go? To a power & lights fuse???
Thanks!
