I have been fighting a speedometer that has been getting progressively wonky. It started out as a quiver in the needle several years back. This turned into a full-blown tsunami of needle swings as the car moved down the road. OMG, talk about annoying!
The tail shaft and speedo gears in the TH350 are all new. I had put two cables in it and made sure the routing was as smooth as could be. This did not fix the problem.
Ultimately, I decided to pull the cluster out and see what may be going on in there.
pulled the speedo..
I could replicate the problem by hooking up my DeWalt cordless drill to the input shaft! Bouncy, bouncy, bouncy. Yay. A liberal application of Zoom Oil in the clockworks and she smoothed right out clear up to a bench speed of 120+ mph. I am calling that a win.
Unsurprisingly, considering its age, a ton of disintegrated foam fell out of the cluster can..
I am learning this a "light seal" - just like they used on the dinosaur cameras we all knew and loved. I ordered some material from FleaBay which seemed a likely candidate.
It seems that me & the X-acto knife have a date. Then, I'll reassemble and giver 'er a go and follow-up.
I found surprisingly little in the forum on the inside of the Instrument Cluster. I figured it couldn't hurt to post some photos.
Anybody else been down this road?
pulled the speedo..
