Well, I finally got my 69 Camaro back out of the shop for sheet metal work. So now it's time to make some engine changes. I have done search after search on the forums to get an answer, but sometimes it just gets confusing.
Here is my current setup:
350 4 bolt main
Flat top pistons (with the 4 eyebrows)
Cast iron intake (4 barrel)
882 heads (1.94 valves)
Holley carb (not sure what it is but it needs help)
RV cam (not sure on what the specs are, but no lumpty lump sound)
Flowtech Ceramic Headers
MSD ignition
3.50 posi (yes it's a Ford 9 but it came with the car when I bought it)
Power brakes
Turbo 350 trans
Stock converter
Will be putting in Vintage Air later this year
The Holley is tired and needs replacing. I'm not ready to swap out the heads and cam (money), and am looking at what will work best for my car. It will be a driver, probably never seeing the drag strip.
What I hope to do later this summer is to replace the heads with cast iron ones and another cam.
What I'm looking for when I change the top end is to have everything working together, taking advantage of each components strength. I would like to have a cam that will produce the lumpty lump sound, but still provide enough vacuum to keep the power brakes/etc going. I know that a lot of you recommend the Comp Cams and Lunati 268 cams. I won't be changing the stock converter until I swap out the trans and put in a 700r4 (next year). Also, I still want to run on pump gas.
My immediate need is for an intake and carb. Most of the posts that I have read recommend either the Edelbrock Performer or Edelbrock Performer RPM. Also, there is a Holley 600, 650, and quadrajet recommendation.
Now with all of this being said, what would you recommend for the carb and intake now, keeping in mind where I'm going with this? Will the performer versus the performer rpm make a difference when it is at idle? This is also my first post, so take it easy on me.
Rick
Vortec cast iron PU truck heads with a Edelbrock RPM Vortec manifold for the Holley should be your first choice. Most bang for the buck. Vortec is the best heads you can buy for street performance and they will support a large cam selection later. The Holley can be rebuilt if it actually needs work. But if it is still running it probably just needs tuning rather than a rebuild or replacement. Just the Vortec heads and manifold will wake up the car, and you can resell your old heads to recover most of the money you spend on the Vortecs.
Larger Dave
I'm not sure you could find worse 350 heads than the 882 smogger heads. I agree with my buddy LD above with his suggestion to chunk'em, but I'd forget the Vortecs and go aftermarket,..some Trick-Flows, or Sportsmans,..or AFR if you have the cabbage.
For carb, I'd find a good quadrajet,..flows 750, adapts to anything, easy to tune (yet many don't bother to learn) and will out mileage a Holley by 10-15% (no kidding).
Good luck!
