Dears,
I open a new topic, as I am not anymore talking about the short block
I am thinking to go for this engine instead BluePrint Engines 383 CI Stroker Crate Engine | Small Block GM Style |
but I did not yet go my option for the 355 vortec.
If finally decide on the 383, I think I will not regret it
but my wallet will be empty
And I need a twin carb/mixer set up to feed correctly the engine, using propane mixers on a holley 4 barrel base plate.
My intention with this topic is to help me understand if my ideas are realistic, if there is a simple option for my application.
Looking at the different options, I can :
- run with my edelbrock performer modified intake, single quad base, on top of it a 90°elbow with Y or Y elbow and 2 mixers, Y is like the black piece of metal on this picture
problem comes with the linkage, make this Y piece special, what about the limit of my intake for a 430 HP engine?
- run a new low profile dual quad intake manifold
Edelbrock 5425 Small Block Chevy Dual Quad Intake Manifold (speedwaymotors.com)
this one is really low rise so I can mount 2 mixers like carbs without issues
I could not install the edelbrock edelborck 7520 dual quad air gap the same way.
- run any other type ram intake with a modified 90° angle flange connection, seems complicate custom built.
Easy way is just to go with the 5425, there are available used on ebay.
BUT :
Any comments are welcome.
I try to evaluate the different options and cost for the complete built. I already am considering the fuel delivery to the engine this is also something.
Thanks!
Marc
BUT :
- they come with a large hole left of the water neck connection, what is that?
- it is advertise good for 1500 - 5000 rpm and the engine considered pulls hard until 5700...
Thanks!
Marc
