Banned
OK, the WCFB intake will have four little-bitty holes. And it's carb mount outline will be sorta scalloped...
The AFB intake will have four bigger holes, but the two in front will be ever so slightly smaller than the rear holes. And squared up..
AND finally the Q-Jet intake will have to little-bitty front holes and two great big rear holes so which intake is it??
And both the AFB and the Q-Jet intake's are darn good for STOCK!!
I doubt if you can even scare up an old WCFB carb. nowadays unless the EARLY 'Vette guys decide to let one go??
pdq67
Banned
AFB means "aluminum 4-barrel"!
I'm not sure about WCFB, "CFB" = "Carter 4-barrel"???
Sorry,
pdq67
PS., you can ID a WCFB real easy b/c it is the only 4-barrel carb. made that has a cast-iron base plate and it is usually all rusty!!
