What would you go with for a 350 small block witha Holley 4-barrel, an RPM air gap or a Victor Jr. Also does anyone know about the Street avenger's. Better than the double pumper's. Thanks
if you are planning on running the car at high rpm a lot, the Victor Jr might be the way to go, but if you are going to be driving around the RPM manifold is probably a better choice. This manifold will give you better throttle response and low rpm power.
it all depends on the cam....if you use a short duration cam, go with the performer intake, if you use a mild duration, go with the perforemer rpm, long duration, go with the victor or vic jr.
Be sure you match all your components together, I havea friend who has a 2.41 gear, a performer manifofld, and a comp x/e 274, and that thing is slow as hell.
